Replacing the front tire
Ok all, I am about to embark on replacing the front tire this weekend. I would imagine it is duable, nothing crazy hard but I would like some advice. What is the easiest way to get a tire off, and what is the easiest way to get the new tire on without wrecking or mangling anything on the bike??
- BuzZz
- Real Name: Never Used Here
- Years Riding: 47
Proper tire levers. Other prying tools may work, but you stand a better chance of not hacking up the rim with proper levers. I've seen guys wrap then with cloth tape in the area they contact the rim in an effort to not chip chrome over aluminum.... I've also seen it go both ways as far as success....
Then it's a game of extreme exertion (to get the bead over the rim, dish soap can help) while maintaining minute control (so you don't slip or scar the rim).
No Witnesses....
- Sev
I still remember you telling me shortly after the first time we went riding how impossible it wasGadjet wrote:Very do-able. I've changed my front tire numerous times myself. Takes a bit of time and some effort, but it's probably one of the easiest tasks that you can tackle.
- Sev
Oh sweet christ, a tubeless low profile tire is a pain in the "O Ring" to change with hand levers. I'll use a machine every time myself
Tube tires are pretty easy to do once you get the technique going. I prefer tire irons for a tube tire as you can be sure you won't pinch the tube.
