Anthony wrote:Nah, custom exhaust, and the guy I got it off re geared the transmition. He has certificates proving he wins races against 1000 cc bikes. I guess he use to drag it.
The amount it would cost to regear a transmission like that would be enough to let you buy two 1000cc bikes.
Custom exhaust will add MAYBE 10hp. And you can gain some top end if you were too alter the final drive gearing you could gain some top end... if the engine were capable of supporting it.
NOW, if you were too maybe overbore the engine, install high-lift cams, high compression pistons, full exhaust, remove the airbox, retune the FI map, alter the final drive gearing, and then slap a nitrous bottle on it...
