What are inverted forks?
Derail
#1 Unread post by Derail »
Can someone explain this to me? I'm reading about it right now, but I don't fully understand it.
Fast Eddy B
My Motorcycle: 02 Fazer FZS600
#2 Unread post by Fast Eddy B »
Inverted:
Traditional
Try wikipedia. It's good.
02 Fazer 600
Derail
#3 Unread post by Derail »
Yeah I just didn't know all the names of the parts at first it made perfect sense the second time i read through. Your pictures would have saved me 10mins of reading though thanks :)
Fast Eddy B
#4 Unread post by Fast Eddy B »
No problem, take it easy
02 Fazer 600
jonnythan
#5 Unread post by jonnythan »
What's the point of inverted forks, though?
#6 Unread post by Wrider »
Less weight to rebound, more weight up top, plus it lessens the overall weight because of the kinds of connectors needed...
#7 Unread post by Sev »
It puts the stiffest part of the fork at the top where it would normally show the most flex. It also allows for a reduction in the length of the inner slider.
Basically it makes a stiffer if somewhat heavier fork. Less flex means fewer problems with inconsistancies in the road whilst the bike is leaned over. The average rider would never notice the difference, but a racer will. Which is why you'll find them on basically every race bike currently in production.
If you want to look at a bike with crappy front end suspension the Yamaha V-Max is a good example.
#8 Unread post by sunshine229 »
I understand that it is also done to help lighten the weight of the suspension. By inverting the forks, there is less weight on the suspension components that move during a bump. Therfore the bike can more quickly and easily return to it's "normal" state after going over a bump.
I hope I got that right! ;)
Andrea :)
Venarius
#9 Unread post by Venarius »
All the race bikes...and the occasional cruiser.
My VTX 1800 has inverted forks.
2003 VTX1800 S
[img]http://img152.imageshack.us/img152/652/dsc02646sr3.jpg[/img]
#10 Unread post by Sev »
sunshine229 wrote:I understand that it is also done to help lighten the weight of the suspension. By inverting the forks, there is less weight on the suspension components that move during a bump. Therfore the bike can more quickly and easily return to it's "normal" state after going over a bump.
Andrea :)
It's also a reduction in unsprung weight, which can greatly improve handling during a turn.
Yes Ven... and the occasional cruiser. If memory serves so does the antiquated Suzuki Marauder.
