What are inverted forks?
I would speculate that one of the reasons why more cruisers and tourers aren't fitted with inverted forks, is because the design puts the most critical exposed part of the fork closer to the road, and closer to the grime and other abrasives that can damage the smooth surfaces.
2004 BMW R1150R
2006 H-D FLHPI
2006 H-D FLHPI
- Sev
More expensive, tougher to service, heavier, thicker, less attractive (to some). There are a lot of reasons not to go with them. There are also a lot of reasons too use them. It all depends on the cost point the bike is being built too, the overall design goal, and what the engineers are willing to work with.
- kabob983
- Legendary 750
- Real Name: Chris
- My Motorcycle: imaginary motorcycle...
Another reason I've heard is because it's easier to make quick suspension adjustments (since the springs are higher) on the inverted forks. The tops of the forks have a bolt that you tighten/loosen to increase/decrease travel.
2004 Suzuki SV650S (Sold)
Being bikeless SUCKS!!!
- tropicalhotdog
- tropicalhotdog
- tropicalhotdog
ah ah ahtropicalhotdog wrote:clearly, my attempts at humor are as successful online as they are in real life.
No ... don't worry ... lets you read my signature ... i thoght not i have understood
Now i have understood your humor ... but i didn't konw those object
Excuse me fr my bad english !! But I'm learning It !
Thank' you :)
Can you correct my grammar errors ?
Thank' you :)
