hmm... doesn't that make you really late for appointments?Flak Monkey wrote:Around here if you have a problem tripping a light you can call and a technician will usually be out there the next day to change the sensitivity.
Actually most sensors in the road are inductive loops that actually sense a change in the magnetic field they create and as such trip the light...Skel3tor1 wrote: To date I have reported two sensors that needed adjusted as they go by weight, and my little 250cc bike isn't near enough to cause it to trip.
ditto here.RideYourRide wrote:If the sensor doesn't work, I run the red. Left turns included. I'm a bad person.
Yup, thats why running the starter whilst over it generally works... electric motors = magnetic fields agumbodr_bar wrote:Actually most sensors in the road are inductive loops that actually sense a change in the magnetic field they create and as such trip the light...Skel3tor1 wrote: To date I have reported two sensors that needed adjusted as they go by weight, and my little 250cc bike isn't near enough to cause it to trip.
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
