Starting issue with 2007 gsxr 600
Gixxerman421
#11 Unread post by Gixxerman421 »
I don't smeel anything... I mean that it won't start..... Not sure how I'm to pay for a "dealership" mechanic to look at it when the accident put me in a back brace and deemed me unfit to work until just today..... I'm still not cleared to lift more than thirty pounds...... I have a family to feed... My daddy doesn't finance my bike, I do....... And Buzzz, thanx for a collosal ( that means big) waste of space and time.... Helpful info only pleeze!!! Spare me the smart ellic remarks THANK YOU!!!! You knew exactly what I was saying..... The motorcycle "CRANKS" but it won't start and run like it should when you "CRANK" it...... no "FIRE" I guess..... Is that right Buzzz?
#12 Unread post by BuzZz »
I'll type this slow for you.
Your bike is new. It has a warranty. It won't cost you anything for them to look at it. It won't cost you anything for them to repair any intrinsic mechanical defect that may be causing your engine to mysteriously lock up.... oops, sorry..... I mean they fix anything that's busted by accident.
They will charge you to fix anything you busted when you crashed or anything you messed up trying to fix it yourself. Once you know what's wrong, you can take the bike back and fix yourself.... well, some people could.
Take it in and make busted engine and screeching noises to describe the problem. They love that.
#13 Unread post by Sev »
Hook the gas tank up correctly, and try again.
Gixxerman421
Tank....
#14 Unread post by Gixxerman421 »
Ok I hooked the tank back up, correctly according to the manual..... Now I'm getting a fuel injector indicator light........ The manual says that in it's current state, flashing "fi" signal, it will not start until the issue is resolved... Trash in the line?
