35 MPh in 6th Gear on a Ninja 250
- Brackstone
- Legendary 1500
- Real Name: David
- Years Riding: 3
- My Motorcycle: 2010/Ducati/Monster 1100
Hi Everyone,
Incase you haven't read my previous post I've been told by the dealer to keep my RPMs under 4k for the first 400 miles.
The problem is a lot of the roads near my area are 40 MpH roads.
The only way I can get up to 35MPH on my bike AND keep it around 4k RPMs is to be in 6th gear.
My question is which way am I doing more damage to this bike? Do I do more damage by keeping it around 4k RPMs at 35mPH? Or by letting it go over 4k RPMs in a lower gear?
Aprilia Shiver 750 (sold)
You might want to read this ...
http://www.mototuneusa.com/break_in_secrets.htm
- Years Riding: 5
- My Motorcycle: 2007 BMW F800ST
IANAM (I am not a mechanic) but most people seem to fall into the "monotune" camp or the "by the book" camp and swear by it. I've heard plenty of anecdotal evidence on both sides.
From my own limited understanding, you aren't going to seriously damage your bike by going a little bit over 4k, but frankly, I'd rather follow the manual's advice unless I really read and digested and felt comfortable with the monotune alternative.
Just another reason to buy used. Let somebody else break it in for you.
2007 BMW F800ST
Re: 35 MPh in 6th Gear on a Ninja 250
He said keep it under not over. also don't stay at the same RPM very big no no in the breakin.Brackstone wrote:Hi Everyone,
- Brackstone
- Legendary 1500
- Real Name: David
- Years Riding: 3
Sorry I'm not sure what you mean by keep it under not over. Did I say I should keep it over? I got confused :olebiker wrote:He said keep it under not over. also don't stay at the same RPM very big no no in the breakin.Brackstone wrote:Hi Everyone,
Also why is staying at the same RPM bad?
- zed
There are two schools of thought:
1- Go by the manual
2- Ride it like you stole it
Pay your money and take your chances!
1- Go by the manual
I had a look at this site and IMHO, another "expert" opinion.Flesher wrote:You might want to read this ...
I always follow the rules.
The only exception to the rule occurs when I make an exception to the rule not to make an exception to the rule and that only occurs under exceptional circumstances.
2005 Vulcan 500 LTD
2005 Vulcan 500 LTD
- Ninja Geoff
- Real Name: Geoff
- Years Riding: 7
I got the impression that you thought it needed to be over even though you said under. The reason that you vary the RPM is a theory that you will have a ridge in the cylinder wall from a very constant RPM. I don't know if thats true but I have always thought that a varied speed and RPM just felt right. My personal feeling is that lugging the thing is not very good either. After the first hundred miles or so I have always starting beating it a little as I do tend ride fairly hard.Brackstone wrote:Sorry I'm not sure what you mean by keep it under not over. Did I say I should keep it over? I got confused :olebiker wrote:He said keep it under not over. also don't stay at the same RPM very big no no in the breakin.Brackstone wrote:Hi Everyone,
My question is which way am I doing more damage to this bike? Do I do more damage by keeping it around 4k RPMs at 35mPH? Or by letting it go over 4k RPMs in a lower gear?![]()
- Brackstone
- Legendary 1500
- Real Name: David
- Years Riding: 3
I know that there are two schools of thought on the break-in period. Some folks at the Ninja 250 forum stand by their opinion that you should ignore the maker's recommendation and ride it the way you normally plan to ride. For me I try to buy used and don't worry about break-in.
As for varying the RPM; that may be a valid practice for a number of reasons, but I don't think that the forming of a ridge in the cylinder wall is one of them. A ridge will always form in the cylinder wall and the placement of that ridge is determined by the point at which the piston stops its upward movement. The ridge will be found where the top-most piston ring reaches its maximum height. Theoretically the piston rises to the same point on every revolution without regard to the RPM. The physical distance from the crankshaft journal (where the push-rod attaches) to the top of the highest piston ring does not vary.
What does vary with RPM is the wear on crankshaft bearings, valve seats, camshaft lobes, valve lifters, timing chain, and piston rings.
For more detailed break-in information on the Ninja 250 specifically a lot of data can be found on the Ninja 250 forum.
JR
JR
