02 honda cbr 600 f4i high running temp question?
shawnhpi
#1 Unread post by shawnhpi »
Ive had it since 880 miles and have 2030 on it now. Im in ROC NY and the temp is usualy 70's - 80's a bit cooler (by the lake). Bike is always running at over 200 and fan kicks on at about 226 and happens alot.
Frame gets burning hot also along with the (gas) adjustable canister for rear shock.
Is something wrong with my bike or am I doing something wrong. Should I get it looked at.
Also what kinda noises or feels should I be looking for while riding to make sure nothing is mechanicaly wrong with the bike.
Any help would be great I just want to make sure its fine so I can ride with out worry.
My bar ends are loose i guess. I can grip em with my hand and turn em. is that bad? I tried to tighten em but they just keep turning. Will aftermarket bar ends fix this or are my handles messed up?
oknow for mod questions
I want an undertail. Where can I go what websites should I look at. I know Hotbodies does not make for 2002 hondas. Bike colour is yellow.
Can any one take a picture of there under tail with out a undertail kit. When I bought mine the fender was all cut up and now i have a wire hangin down I pull the end and it releases the rear seat. My main sit also is held on by screws is that correct?
Word
2006 Honda CiViC si FBP #1388
2004 Kawa SXr 800 piped
2004 Kawa SXr 800 not even broken in yet!
2002 Honda CBR 600F4i
My life... Its above me.
#2 Unread post by Sev »
Check your coolant levels to start with. They might be low or need replacing.
As to the bar ends, try removing them completely, it's possible that you have a set that are designed to spin on the end. Just a puck that spins along the screw that holds them in place. At the very least you can check them and see if there is threading inside that has warn off, or notches that were rubbed down allowing it to spin.
And I think this should be somewhere in the maintenance forum.
shawnhpi
#3 Unread post by shawnhpi »
thanks for a quick reply.
How Do I check the coolant level?
I will get some pics of the bar ends to show who ever needs to see em..
Thanks
SHawn
Word
#4 Unread post by Sev »
user manual...
Psycluded
#5 Unread post by Psycluded »
http://forums.cbrworld.net/forums/158468/ShowPost.aspx
Sorry to link to another forum, but there are a lot of WERA racers in this (CBRWorld.net) crew, and this thread asked pretty much the same question.
Just for reference, my 2005 F4i quickly hits 225 in stop-and-go traffic. The fan takes care of it, though. So long as the bike doesn't hit 250+, you're fine.
-Psycluded-
2005 Honda CBR600F4i - STOLEN
2005 Honda CBR600RR Black Tribal Edition
shawnhpi
#6 Unread post by shawnhpi »
here are some pics of my bar ends that i think might be messed up..
First pic is of t he full bar (look at the bar end to the grip, looks crooked).
Next pic just another view
Next pic is of the bar with the end off.. The silver part (highlited in green). where the screw threads into actually turns when scre and bar all the way in..
And last pic is under my rear seat with the cable I use to release it. When i put on the undertail kit how Will I be able to get the seat off?
I am buying this undertail kit http://store.58cycle.com/ProductDetails ... w&CartID=2
Word
shawnhpi
#7 Unread post by shawnhpi »
http://store.58cycle.com/ProductDetails ... r&CartID=3
Was wondering also if this would help with my temp issues.?
Thanks
Shawn
Word
#8 Unread post by Sev »
In the illustrious words of my coworker. *newfie accent* "Billy she's been dropped!"
Looks like it landed on the bar end, and rather then replacing the whole handly bar someone just bought a new end. I'd make sure that your bars are still true.
shawnhpi
#9 Unread post by shawnhpi »
OK ill have t hat checked out.. But how hard is it to replace bars.. Can I do it myself?
Thanks
SHawn
Word
