what the heck keeps a motorcycle battery charged
- Legendary 1000
Not sure how many. It was used on the Rotary valve 2 strokes that came out in the late 50s and are still being produced but not imported to NA. (I think) Lifian and some of the other smaller Chinesse and Tiaweneese bikes and scooters still use this system also. Never saw this set up on anything larger than 125cc.
- mydlyfkryzis
- Legendary 500
- Years Riding: 42
A magneto puts out a DC voltage spike. No rectifier needed. The coil on the bike produces the high voltage spark directly. 200 gadzillion Briggs and Stratton engined lawn mowers can't be wrong.slimcolo wrote:My Yamaha uses a magnito for both the charging and ignition circuits. The charging circuit goes through a rectifier to change voltage and current. this is wired directly to the ignition switch and thus to ignition coil. Other side (DC) of rectifier goes to lights.
You may have both a magneto and a charging circuit. This way the bike runs even if the 12V systems crashes.
Most, if not all, small aircraft use magnetos for this reason. In fact, they usually have 2 magnetos for redundancy. They also have a separate alternator system for powering the instruments and lights.
Richard - Fully Dressed
Naked 1976 Honda CB360T
