GS550E
T Co
bolt
#11 Unread post by T Co »
I'll chquec behind the clutch basket as this is the only place I could imagin that it could go If I find a result from your discription you will surly get the fiver if not I'm sorry but you won't.
T Co
Bolt
#12 Unread post by T Co »
This is really f***ing me off now, I've chqueced all areas in clutch housing are,in cam shaft top end and all casings and still am finding on place for this bolt!how do you put a picture to these messages as someone might reconise this sod of a bolt.
#13 Unread post by Johnj »
You need to upload a picture to Photobucket or some similar service so your picture has an URL. Then put the URL in between the img brackets.
Code: Select all
[img]http://www.yourpicstorage.com/drive47/yourpicture.jpg[/img]
Above you see what the line will look like. I'm going to use one to display the graphic below.
T Co
Pic!
#14 Unread post by T Co »
Image found photo bucket but the image is not showing prob because the address is in the wrong place eh!
T Co
#15 Unread post by T Co »
Code: Select all
[img]http://s212.photobucket.com/albums/cc94/TColling/[/img]
T Co
Pic!
#16 Unread post by T Co »
Where's me picture!
#17 Unread post by Johnj »
Are you talking about these pictures?
T Co
#18 Unread post by T Co »
Eh!,What,How,Little b***ard thing.A week away from running the beasty up oil sat by the side of her and this bolt,I know almos every milli of the engine but not were thid little sod of a bolt goes huh! :twisted:
olebiker
Re: ?
#19 Unread post by olebiker »
T Co wrote:Eh!,What,How,Little b***ard thing.A week away from running the beasty up oil sat by the side of her and this bolt,I know almos every milli of the engine but not were thid little sod of a bolt goes huh! :twisted:
I can't make heads or tails out of what you are trying to say.
Re: ?
#20 Unread post by BuzZz »
+1
Are you sure that bolt is from your engine internals? It almost looks like an engine mount bolt or some bracket fastener maybe...
