way to 'force' start the motor? [kickstart broke]
#11 Unread post by dr_bar »
If you want to totally trash it, just start crossing wires without knowing what you're doing. Get a manual or take it in for service...
rotten_yellow
#12 Unread post by rotten_yellow »
The manual doesn't say anything, but how to change oil etc.. I got 'motorcycle mechanics guide'. I'm not gonna take it to the service, unless I'm left with no options. I don't feel like paying 50$ and up for just getting a starter to work.
I noticed that my lights go dim when I press the starter button, so I guess not enough power comes from the solenoid to start the motor. Does that mean I need a new solenoid or there could be something else that interferes the process?
Axman
#13 Unread post by Axman »
I think you need a battery.
rotten_yellow
#14 Unread post by rotten_yellow »
Axman wrote:I think you need a battery.
Multimeter showed 12,5v for the battery, the voltage would have appeared lower if the battery was bad.
Tennif Shoe
Years Riding: 5
My Motorcycle: VTX 1800c
#15 Unread post by Tennif Shoe »
check batt voltage while hitting the start button, a bad batt can show 12.5 volts but not have enough juice (amps) to start up. You may find that when you hit the start button it goes to 2 volts. that is not enough to start the bike
03 Honda VTX 1800c
87 Yamaha TT350
86 Kawasaki Vulcan 750 (sold) Have fun in Mexico Mr. Vulcan!
YES my spellin sucks, get over it, or you can be my personal spell check
rotten_yellow
#16 Unread post by rotten_yellow »
Thanks, I'll try it after a sec.
I figured out that I could start the bike by attaching wires directly from the battery to the starter motor, and give it a little spark. The only problem is the starter motor gear stays 'inside', theres like one inch gap between the gears.
NorthernPete
Years Riding: 11
#17 Unread post by NorthernPete »
post pictures when your bike explodes please.
and wear saftey glasses..those bits of metal are gonna fly!
2009 GS500F
rotten_yellow
#18 Unread post by rotten_yellow »
Got it working!! The problem was lose connection in the solenoid and starter motor was busted. Thanks everyone who helped!
MrShake
#19 Unread post by MrShake »
are you REALLY going to ride it with a big hole in your engine case from that broken kickstart?!?!?!
1976 Golding GL1000 Bagger
Axman
#20 Unread post by Axman »
It's a James Bond smoke screen/oil slick device!
