Things to make you more visible?
What are some things that will help you be seen?
Other than the actual color of the gear, what else is out there?
A helmet halo
Reflective neon vest
Rim tape
Anything else?
A helmet halo
Rim tape
Anything else?
Current ride: 05 XB12R
Sold: Yamaha R1
Sold: Yamaha R1
- Mustang
- Legendary 300
Not sure if this is the type of answer you're looking for, but I had an attachment added that makes my indicators/brake lights blink three or four times when I brake. Catches the eye of cars behind me.
Otherwise its apparel with a lot of reflective material.
[b]Other Daily Reads[/b]
[url=http://bikerdiaries.blogspot.com/]Biker Diaries[/url]
[url=http://www.clutchandchrome.com]Clutch and Chrome[/url]
[url=http://totalmotorcycle.com/BBS/index.php]The motorcycle Forum[/url]
- Grey Thumper
- Legendary 1000
- Real Name: Dino
- Years Riding: 9
I strap a scubadiving strobe light to my left bicep. Seems to work fine, a trailer truck that was gonna creep into my lane even got out of the way suddenly (though I'm just assuming it was because of my strobe). I sometimes wonder if it annoys people though; it's almost as bright as a camera flash.
- Patrick
- Legendary 300
- Real Name: Patrick
- Years Riding: 30
- My Motorcycle: 1998 V-Twin 1500 & 2008 Suski C50T
As well as use my indicators I use a lot of hand signals for turns or breaking. The older folks know what they mean and pay attention and the younger ones, well at least they see me.
Pj
Pj
Keep the wheels on the road.
If you want check my blogg at this site.
http://www.totalmotorcycle.com/BBS/viewtopic.php?t=25466&postdays=0&postorder=asc&start=0
Headlight Modulator. I use: http://www.kisantech.com/index.php?cat_id=2
Brakelight Modulator. I use: http://www.kisantech.com/index.php?cat_id=3
There are less expensive modulators out there, but they require a little re-wiring. The ones I linked to, and use on my bike, truly are "plug and play." If you can change the bulbs in your headlight and brakelight, then you have the skills necessary to add those items.
- Fast Eddy B
- Legendary 500
- Years Riding: 12
- My Motorcycle: 02 Fazer FZS600
Lane positioning.
For bikers, when approaching junctions you should consider 'moving about' in your lane. Obviously this shouldn't be done if it will create a collision/near miss/wind buffet. Moving slightly across a lane can create movement between you and your background the other driver sees. It is this movement that helps drivers to see smaller objects.
For everyone one road, stay away from blindspots, and leave plenty of room behind a vehicle before an overtake, to maximize vision ahead.
- dean owens
- Legendary 500
- My Motorcycle: '06 Yamaha Fz6
i've recently started reading proficient motorcycling. he was talking about the whole being seen thing. although i don't know if this is true he thinks that most cars that say they didn't see the biker are lying. it's easier to say i didn't see you then, yeah i saw you but i wanted to get somewhere quick and thought you would stop or get out of my way.
his advise is to drive like you're invisible and don't plan on someone else seeing your or keeping you safe.
that said, i try to make sure i'm seen but still riding as though no one can see me.
things i've done...
try to get gear that is light in color (haven't always succeeded here)
put reflective tape on gear
try not to ride at dusk
do the weaving deal that was said
try to hit the breaks a few times before actually stopping
i have a front mod but don't always use it
things i've done...
Current: 2006 Yamaha FZ6 (Faster Blue)
Previous: 1983 Honda GL650 Interstate (given back to previous owner)
Project: 1980 CX500 Custom - making a cafe racer
