how to check oil
- pinger05
- Legendary 300
- Real Name: Dan
- Years Riding: 10
- My Motorcycle: 2005 Yamaha V-Star 650
how to check oil
Ok stupid question. How do you check the oil in a 05 Yamaha V-Star 650? There is no dip stick that measures how much oil is in the crankcase. All that I can see when I unscrew where I think the oil goes is a piece of plastic and no oil.
I have tried to find information on Google but so far I cant find a manual or any good information. But then again I am not a master Googler.
2005 Yamaha V-Star 650 Classic
Ural Patrol <Wish list>
All it takes for evil to triumph is good me to do nothing
- Gadjet
- Real Name: Owen Clark
- Years Riding: 19
- My Motorcycle: 2020 KTM 200 Duke
- Contact:
there is a sight glass at the bottom of the cover below the oil filler cap. check the level in the glass with the bike upright (get a friend to hold it if necessary) There will be marks on the glass to show where the oil level should be.
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
Good call. On that same note, if you want to do your own changes do them with a warm engine. After refilling, run the engine for a minute then recheck the oil level again.Big B wrote:warm it up first, has to be at operating temperatures to correctly gauge the oil level, otherwise you run the risk of overfilling
- Sev
You cannot have oil in the crank case of a two stroke. You can have clutch or tranny oil though.getthecatscotty wrote:theres an oil fill by the handle bars for the 2 stroke oil but theres an oil fill on the motor for the crankcase
- BuzZz
- Real Name: Never Used Here
- Years Riding: 47
I've never owned a PW, but every 2 stroke dirt bike I have had has always had a level check screw/bolt on the tranny. Remove this screw and when oil comes out of the hole with the bike level, it's full. The screw has never been marked, but there has always been a volume number cast into the cases someplace close by it. Most hold about 800cc-to a liter, your PW might be less... like 500-600cc, but that's just a guess.
No Witnesses....
