The perfect bike is DIESEL??
TechTMW
#1 Unread post by TechTMW »
The bike is powered by a VW 1200cc 3 cylinder diesel car engine, turbo and intercooled.
74.5 kw @ 2500rpm. (100hp)
200+nm torque. (147+ lb-ft)
Compression ratio 16.0:1.
100km/hr in first gear.
Weight 205kgs. (551 lbs)
Fuel consumption 2.5litres per 100kms. (94mpg us)
Unfortunately the only information I could find on this bike is in Dutch. :|
Sounds too good to be true. If they enter production, I'm sure america won't be seeing them :laughing:
Here's a link http://www.canyonchasers.net/blog/archi ... cycle.html
This link gives different specs than the ones I uncovered ... hmmm
Gummiente
Years Riding: 38
My Motorcycle: 03 Super Glide
Re: The perfect bike is DIESEL??
#2 Unread post by Gummiente »
TechBMW wrote:100km/hr in first gear.
I wonder how long it takes to get there, though...
:canada: Mike :gummiente:
It isn't WHAT you ride,
It's THAT you ride
Gadjet
Real Name: Owen Clark
Years Riding: 19
#3 Unread post by Gadjet »
TechBMW wrote:Weight 205kgs. (551 lbs)
typo. should be 451lbs
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
Sobereality
#4 Unread post by Sobereality »
i wonder if its bio deisel 8)
[img]http://www.thegreatcornholio.com/images/cornholio/cornmov.jpg[/img]
MASHBY
Years Riding: 20
#5 Unread post by MASHBY »
Enfield came out with a Diesel bike about 10years ago.500cc and on a good day could top 60mph.And do 150mpg
Gummiente
Years Riding: 38
#6 Unread post by Gummiente »
MASHBY wrote:Enfield came out with a Diesel bike about 10years ago.500cc and on a good day could top 60mph.And do 150mpg
Back when I was posted in Germany around '84, I rode past a gas station one day and saw a Triumph Bonneville at the diesel pump. :shock: It did not have a parallel twin Triumph engine in it and by the time I was able to turn around and go back to the gas station for a closer look the bike was gone. I never saw it again and I've never heard of Triumph ever making a diesel bike, so to this day it remains a mystery to me.
It's THAT you ride
MASHBY
Years Riding: 20
#7 Unread post by MASHBY »
Well germany is very pro diesel.So probaly on home built.ON another diesel note Turbines run great with Diesel.
So this would be my prefered Diesel Bike
MTT Turbine SUPERBIKE.
Engine:
Rolls Royce Allison
250 series gas turbine
Power
320 HP @52,000 rpm
(286 HP @ rear wheel)
Torque:
425 ft/lbs @ 2,000 rpm
Output RPM:
6,000 rpm
Compressor Speed:
54,000 rpm
Weight:
500 lbs
Frame:
aluminum alloy
Fairings:
carbon fiber
Rake:
27 degrees
Seat Height:
31.5 in
Wheel Base:
68 in
Wheels:
17" carbon fiber, Dymag
Tires - Front:
120 60ZR17, Pirelli
- Rear:
200 50ZR17, Pirelli
Brakes:
3x320 mm floating system- 4 piston
calipers, Brembo
Shocks:
mono-shock adjustable
oleopneumatic, Ohlins
Front Forks:
55 mm inverted
Fuel:
diesel, kerosene
Fuel Capacity:
8.5 gallons (34 liters)
Lubrication:
dry-sump/3.5 quarts turbine oil
Transmission:
2 speed automatic
Rear View:
rear mounted camera with LCD color
display plus side mirrors
Seat:
single or double
Colors:
infinite custom colors
Aggroton
#8 Unread post by Aggroton »
Sobereality wrote:i wonder if its bio deisel 8)
any stock diesel engine will run on bio diesel....
i before except after c.
thats a sweet bike.
Nibblet99
#9 Unread post by Nibblet99 »
OR USED CHIP FRYING OIL
tristan_s
#10 Unread post by tristan_s »
i know that a diesel engine can be converted into a gas engine; i wonder if you could do it in reverse? (not that it would make much sense financially). If you could make a bike that could actually get up to speed reasonably quick and got 100+ mpg, you'd make a mint nowadays.
diesels have an advantage over gas engines when it comes to low end torque which is why they are popular in trucks and whatnot, plus it takes them very little effort to sustain speeds (again part of the reason they are used in semis; they can maintain a good cruising speed for a long time). the downside is that after that initial good torque, they tend to take ages to get up to normal speeds. that's why turbodiesels are so popular; the turbo is usually tuned to kick in in the mid RPM's to assist in getting the car up there.
the Germans have gotten pretty good at it; a 1.9l VW TDI Golf that I drove felt quicker off the line than a regular 2.0 gas version, and about the same in the mids (though the RPM's on a diesel are way lower anyway, part of the reason they also tend to last longer). The engine on that bike is probably out of a Lupo 1.2 TDI, since it's turboed and whatnot.
biodiesel can be burned in any diesel engine and really isn't such a bad idea. go over to the vwvortex forums and people will tell you it's the seed of evil, and that hybrids are a big joke. i think a hybrid diesel/electric engine with an electrically assisted intercooled sequential twin turbo would be sweet.... and still probably get 80+ mpg in a car.
