Need plug wire help
Krtismo
Need plug wire help
#1 Unread post by Krtismo »
OK, So I'm putting new plug wires and caps on the CB750 I'm restoring and I noticed a difference in Ohms between the new set and old set.
My old wires with no caps are showing .2 Ohms
New wires with no caps are showing 11 K Ohms
What gives?
Here are the New Wires:
http://www.z1enterprises.com/detail.aspx?ID=1310
Thanks!
-Kurt
mydlyfkryzis
Years Riding: 42
#2 Unread post by mydlyfkryzis »
Did you buy the copper core (Low Ohms) or the carbon core (High ohms).
The higher ohms will give you a higher voltage spark, assuming your coil can deliver it.
Richard - Fully Dressed
Naked 1976 Honda CB360T
Krtismo
#3 Unread post by Krtismo »
There is a link to the wires I bought in my first post. I also still have the stock coils.
I should probably note that the stock wires have 5 K Ohms caps on them and I have replacements for those.
With the caps on, my stock wires showed about 5 K Ohms
With the caps on, my new wires showed about 13ish K Ohms
mydlyfkryzis
Years Riding: 42
#4 Unread post by mydlyfkryzis »
I seen the link, it just seemed a little unclear as to the exact composition. It appears the gray wires are the carbon core.
The resistance test is supposed to be from spark plug cap to cap on one coil.
Total 18-22K ohms
From wire to wire (Caps off) 13-17K ohms
Coil alone (secondary side) 13-17K ohms
Since coil alone and coil with wires are the same, I expect that honda prefers the copper core wires. ie: low resistance.
I suspect that you won't have any problems with the suppression wires despite their slightly increased resistance.
Next time get the copper core wires though...
Krtismo
#5 Unread post by Krtismo »
This bike has electronic ignition though, Wouldn't that require suppressed core wires?
I guess I should give more info about the bike, It's a '82 CB750SC Nighthawk.
