Does gasoline boil?
Does gasoline boil?
I ride a vulcan 750 and recently had its 9000 mile maintenance work done. On my next ride, I went about 70 miles and when I stopped and turned the bike off, I noticed a hissing sound from the gas cap. I loosened the cap to release the pressure and then tightened it again. After about one minute the hissing sound started again. I opened the cap and the hissing stopped, so I left it open for a few minutes. When I returned about 15 minutes later, I heard gurgling coming from the tank and when I looked insde, the gas was bubbling just like when water boils in a pot. I have never had this happen before, but I've never looked in the tank when I returned from a trip before. I have never heard this before when I have stopped to fill up during a ride.
Does gasoline boil?
Is the situation I've described dangerous?
Logically, it seems to me that you shouldn't ride around sitting on top of a tank of boiling gasoline.
I asked the service manager at the Kawasaki dealership and all he could tell me was to leave the gas cap tight and let it hiss. He said that the gas cap had a vent to allow the pressure to release. He could not answer my question as to why the gas was bubbling and gurgling like it was boiling.
Does anyone out there have any experience or knowledge with situations like this?
Does gasoline boil?
- Gadjet
- Real Name: Owen Clark
- Years Riding: 19
- My Motorcycle: 2020 KTM 200 Duke
- Contact:
can gasoline boil? yes. it's a liquid.
can it boil in your tank? I don't see why not if the tank gets hot enough (heat coming off the engine, sun beating down on it, etc....)
Leave the cap on and let the vent do its job.
Dangerous? Not unless you pop the cap off and hold a lighter over the fill nozzle.
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
- Regular
I remember clearing some land I had in West Virginia for my cabin and all I had was a 14 cheap chain saw........
Yea, gasoline boils like chicken soup!!!! that little chainsaw was boiling like crazy......I added more gas and kept cutting.....
Of course I was younger and dumber then......
Don't recall it ever doing it in a motorcycle though?
dan
dan
2008 Suzuki C50T
- BuzZz
- Real Name: Never Used Here
- Years Riding: 47
Gasoline boils. The gasoline in your tank is not boiling. It is absorbing heat and expanding. It is also vaporizing and heat helps this along. The hissing noise is the vent on your tank or cap letting that pressure escape looooong before it gets anywhere near high enough pressure to explode. You can open the cap and release all the pressure present at that time at once, or you can leave it and let the vent to it's job, whatever you prefer. Just take the smoke out of your mouth before you bend over to loosen the cap.
As the tank and fuel cool, or you ride the bike and draw fuel out of the tank, that same vent will allow air back into the tank to prevent vacuum building and starving the engine of fuel.
No Witnesses....
- jonnythan
But he said the fuel was visibly bubbling, like boiling water.BuzZz wrote:Gasoline boils. The gasoline in your tank is not boiling. It is absorbing heat and expanding. It is also vaporizing and heat helps this along. The hissing noise is the vent on your tank or cap letting that pressure escape looooong before it gets anywhere near high enough pressure to explode. You can open the cap and release all the pressure present at that time at once, or you can leave it and let the vent to it's job, whatever you prefer. Just take the smoke out of your mouth before you bend over to loosen the cap.![]()
- BuzZz
- Years Riding: 47
So he did, my bad. But I still am not convinced it was boiling, at least from temp. It could have been bubbling from the sudden pressure release of opening the cap... technically boiling, I guess, but at a lower temp, or it could be vapor lock in the fuel line backfeeding as the tank is opened or something similar. Or it indeed could be boiling due to temp on a hot day with alot of heat kicking off the cylinders into the tank bottom. The tank is designed to take care of all of this with the vent system, so doing nothing is the best remedy. A cool down phase and parking in the shade with some air circulation couldn't hurt either....jonnythan wrote:
No Witnesses....
