what does it mean when they say to chaulk a nut
assmunch13
#1 Unread post by assmunch13 »
can anyone help it said to chaulk the nut i need help
ofblong
Real Name: Ben
#2 Unread post by ofblong »
no idea what your talking about but google results come up with
http://www.google.com/search?hl=en&clie ... 22&spell=1
96' Honda Shadow Deluxe VLX
assmunch13
thanks been there no help
#3 Unread post by assmunch13 »
thanks been to all the searches and have had no help thanks anyway
the_sandman_454
#4 Unread post by the_sandman_454 »
What sort of context was it in? Did you read it, someone say it, or what? If you read it, tell us what else the thing you were reading said before and after it, and maybe a picture if there was one.
mgdavis
#5 Unread post by mgdavis »
Marking a fastener to show that it has been torqued?
'07 Suzuki V-Strom DL650
Molon Labe!!!
the_sandman_454
#6 Unread post by the_sandman_454 »
The only other thing I can think of is maybe they meant "staking" the nut, which would prevent it from backing off if done properly. I surely wouldn't do that without a second opinion.
#7 Unread post by dr_bar »
mgdavis has it right. The process of Chaulking a nut, is to mark the nuts you've torqued, as they are completed. This prevents over-tightening or improper torquing of nuts by letting you "SEE" which ones you've already torqued...
Does that make sense??? :roll:
Brackstone
Real Name: David
Years Riding: 3
#8 Unread post by Brackstone »
mgdavis wrote:Marking a fastener to show that it has been torqued?
+1
Aprilia Shiver 750 (sold)
ofblong
Real Name: Ben
#9 Unread post by ofblong »
glad someone was able to provide insight cause I had never heard the phrase either :D.
Shorts
#10 Unread post by Shorts »
Hmm I was thinking it was like "chalk a nut" like you'd chalk a que stick. Only this was a phrase used similar to 'cowboy up'. So, chalk your coin purse and saddle up for the ride! :roll2:
