You called that one right.Shorts wrote:You know, your switch could be busted and the brake light is actually on. I had this little error when I was doing my control switch over. Unless the switch is in good order, it can remain closed and the brake light stays on.
Pull your switches, shouldn't take long at all to check the front brake.
Just switch, not a big deal.
