First service
HYPERR
#11 Unread post by HYPERR »
Big B wrote:
HYPERR wrote:600mile service is just a glorified oil change. Even the ultra maintenance intensive Ducati does not require much more than that.
yamaha also recommends a valve adjustment at the 600 mile "initial" service, and they're a pain in the "O Ring" to get at, hence the higher price
Is this a recommendation or a requirement to check the valves at 600 miles?
And if it is required, I would assume that it is a lock nut adjuster instead of shims. In that case, it should be an absolute cake to adjust it(assuming the tolerances are off), especially on a twin.
Granpooba
#12 Unread post by Granpooba »
Maybe you folks should talk to factory tech reps ! 600 mile check like one fellow mentioned is a glorified oil change. And that is all that I had. And as for valve adjustments, that 600 miles has been changed to 4,000 miles, and that came from the factory, not the blood sucking dealers !
#13 Unread post by dr_bar »
My service cost a lot more but with all the plastic they have to remove to do the service, the difference is all labour related...
