turn signal issue
turn signal issue
i got some new turn signals all around for my 81 yamaha xj650 and the old ones had 3 wires and the new ones have 2 wires ... i assume this is because the new ones dont work as running lights .. but my problem is that when i hit the turn signal switch the turn signals ligt up but dont blink .. i have changed the relay and still no blink ... any help?
An expert is someone that knows so much about so little...
- Gnarlyroad
- Veteran
turn signals
Ya you have your power wire connected to the running lights. Need to switch the wire over to the signal light wire. Put a meter on the wires left over from your conversion. Turn on the signal lights and see which one blinks. Thats the one ya want. Easy to do when going from 3 wire connection to a 2 wire connection.
- insaneman_12
- Veteran
- Years Riding: 25
- My Motorcycle: Motorcycle
If all of the signals are not hooked up they will not blink. The flasher unit does not kick on untill there is a complete circut. For example you have to have, for the left side, both signals and the turn signal indicator hooked up to make them flash. Plus both signals have to work. The three wires mean one is ground, usually black. One consistant hot for running lights, usually the striped wire. One flasher hot, usually solid wire. You do not need the consistant hot if the signal only has two wires just make sure the wires don't touch ground.
71 CB 750 K1
94 PC 800
76 CB 550 K
75 TS 185
76 TC 185
63 YSA-1
06 YZ 450F
84 XL 350R
02 KX 85 with 75 XR 75 motor XR 200 sus.
94 PC 800
76 CB 550 K
75 TS 185
76 TC 185
63 YSA-1
06 YZ 450F
84 XL 350R
