Cb360t singals upgrade
HammerDown
#1 Unread post by HammerDown »
I'm wondering what kind of say aftermarket turn signals i could put on this old bike. I wanted to bring them closer to the frame instead of the original one that sit about 5-6 inch's out. I was looking at some led ones but, i don't know if they would work with my setup both mounting and electrical. Thanks for the help.
mydlyfkryzis
Years Riding: 42
#2 Unread post by mydlyfkryzis »
Actually, LED signals would help reduce the electrical draw. But you will need to get a flasher that works with LEDs. If you put a resistor in, as many people recommend, the flashers will work, but will draw the same current as the original.
Mounting, you will need to use a little ingenuity. I mounted my OEM signals on the luggage rack support to accomplish this. You may need to figure out a way to do it.
Richard - Fully Dressed
Naked 1976 Honda CB360T
HammerDown
#3 Unread post by HammerDown »
thanks mydlyfkryzis, does anyone have any recommendations for led?
