shockrocker
Posts: 4 Joined: Mon Sep 01, 2008 10:01 pm
#1
Unread post
by shockrocker » Tue Sep 02, 2008 10:15 am
ok, was able to find out the model, 1982 yamaha XT200J dirtbike.. i need the lever for the kickstart, the wire that connects to the sparkplug and possibly the coil as well.... is there anyway i can rig these to work w/o having to buy the actual part? it doesnt have to be street legal or pretty, i just need it to work, thanks
Posts: 4726 Joined: Sat Mar 20, 2004 12:02 am
#2
Unread post
by BuzZz » Tue Sep 02, 2008 11:56 am
A kick start lever might be found at a local bike wrecking yard, or online.
You should be able to remove the old high tension lead from the coil and reinstall a new replacement form a parts store.
No Witnesses....
ofblong
Posts: 2638 Joined: Wed Apr 26, 2006 6:51 pm
Real Name: Ben
#3
Unread post
by ofblong » Tue Sep 02, 2008 12:16 pm
I have always hurd it as jerry rig.
96' Honda Shadow Deluxe VLX
shockrocker
#4
Unread post
by shockrocker » Fri Sep 05, 2008 1:05 pm
well, just in case, how do i make a new sparkplug wire/ coil connector if i cant buy the real thing?
Skier
Posts: 2242 Joined: Sat Aug 07, 2004 10:44 am
#5
Unread post
by Skier » Fri Sep 05, 2008 1:56 pm
shockrocker wrote: well, just in case, how do i make a new sparkplug wire/ coil connector if i cant buy the real thing?
I suppose you could use a set of spark plug wires from an auto parts store. They have cut-and-crimp-to-length kits.
fireguzzi
Posts: 2248 Joined: Fri Aug 20, 2004 3:00 pm
Real Name: Trevor
#6
Unread post
by fireguzzi » Fri Sep 05, 2008 4:23 pm
Coat hanger and a bunch of electrical tape.
That's a joke by the way.
slimcolo
Posts: 1232 Joined: Sat Jun 02, 2007 7:33 pm
#7
Unread post
by slimcolo » Sat Sep 06, 2008 3:06 am
Really, I actually had to use a piece of barb wire I cut off a fence for a plug wire. It got me home where I had another plug wire. (only bit me once)
