I have rearsets!
ronboskz650sr
I have rearsets!
#1 Unread post by ronboskz650sr »
Well, you never know what you'll get from EBAY bikes. I haven't had another kz 650 (or even a ujm, for that matter) to compare with my bike side-by side. I knew it felt sportier than it probably should for a UJM, as 30 year-old memory served. And I know I have a blast on it...And I've wondered why my son's Hurricane feels so natural to me. Well, some guys have been posting pictures on another forum of recently restored bikes like mine. As I studied them, i discovered my bike has rearsets! That explains the more aggressive riding stance (which I like), and why I step on my daughter's feet sometimes leaving a stoplight, and why my tires go away on the edges, but my pegs don't scrape! It also explains why I don't feel cramped or bent over too much on Chris's CBR. Learn something new every day! :laughing: :laughing: :laughing:
Feeling a little silly.
Ride safe...God bless!
-Ron
rapidblue
#2 Unread post by rapidblue »
newb question... what are rearsets
80 honda CB750F Super Sport
pappy1398
#3 Unread post by pappy1398 »
Black 2005 Honda Shadow Aero 750
www.donbroyles.com
ronboskz650sr
#4 Unread post by ronboskz650sr »
A way to reposition the footpegs and foot controls rearward and up for better cornering clearance, and a more aggressive riding position...in a nutshell the brackets are replaced, along with anything else (usually including the pegs and controls themselves). On my bike the rear brake pedal is shorter, and the shift lever is actuated by your foot through a linkage to the transmission. The original shifter was a direct connection to the knurled post coming through the sprocket cover. Everything on my bike is 4 or 5 inches rearward and about an inch higher than stock. The footpeg on the left used to be about where the shifter is now. The brake is where the old footpeg was on the right. The overall effect is to push the upper body forward, because the feet go behind you. Now I know why I've been getting the urge to put clubman bars on for a real cafe racer ride! It all kindof goes together toward the common end.
-Ron
canuckerjay
#5 Unread post by canuckerjay »
Congratulations!!
Doesn't sound too comfortable, dude.
Wherever you may roam
May you own your road.
rapidblue
#6 Unread post by rapidblue »
right on sounds cool
thanks for the info
ronboskz650sr
#7 Unread post by ronboskz650sr »
canuckerjay wrote:Congratulations!!
Actually, very comfortable. I can ride until the tank is empty, fill up and do it again...over and over. Remember, 1979 bike. the overall layout of the bike won't cause a radical forward position unless I put the clubman bars on. Then it would be cafe racer riding position, similar to modern sportbikes. Not bad.
-Ron
mysta2
#8 Unread post by mysta2 »
nice, I think that will be in the cards for me some time soon too. Are your' toes prettymuch straight down when you ride?
[url=http://www.cafepress.com/dropbars][img]http://www.dropbars.com/cafepress%20banner.jpg[/img][/url]
Check out my [url=http://www.totalmotorcycle.com/BBS/viewtopic.php?t=5844]blog[/url] for the latest on my little project.
ronboskz650sr
#9 Unread post by ronboskz650sr »
mysta2 wrote:nice, I think that will be in the cards for me some time soon too. Are your' toes prettymuch straight down when you ride?
They would be nearly straight down (not quite) if I hooked my boot on the heel, and sometimes I do on the freeway just to stretch for a couple seconds. I ride with the ball of my foot on the peg the rest of the time, after the shifting is done, until a downshift is needed or a little rear brake ( like holding on a hill at a stop sign, or in a parking lot, etc.) Most of the time, out in the country, my foot is positioned heel up and behind me. If the pegs were further back, I guess I might hook my heel on them...Did that answer your question?
-Ron
ronboskz650sr
#10 Unread post by ronboskz650sr »
Here's some more information. The general consensus on Kzrider forum is that my "rearset" may be the stock brackets switched to the other side and inverted, or some variation of that. For folks with a UJM, this is definitely worth investigating with minimal wrenching. If you find a workable "rearset" position using your stock brackets, you'll have to fabricate the shift linkage and brake pedal (probably can shorten this and weld the pedal back on.) Whatever it is, It took some thought and some fabbing or salvage yard shopping to find workable pieces. I'm glad he did it, whatever it was!
-Ron
