Exhaust tubing for garage
LS1GOAT
#1 Unread post by LS1GOAT »
Can anyone recommend what to use or where to look for exhaust tubing to cover my bikes' exhaust while I'm working on it in my garage?
#2 Unread post by Johnj »
I found some things that could work for you by searching Google for exhaust tubing.
:frusty:
LS1GOAT
#3 Unread post by LS1GOAT »
I was looking more for a suggestion about what kind people use and if you can get it at any major chains (Home Depot, Sears, etc).
#4 Unread post by Johnj »
Get PVC pipe in the proper diameter to fit over your exhaust pipe and run it out the door. Get a couple 45º fittings and a can of PVC glue and custom make them so they drop to the floor and run under the garage door. You could even install dryer vents in the wall and get some flex pipe in the proper diameter.
slimcolo
#5 Unread post by slimcolo »
Some of the bendable auto exhaust tubing works best if you can still find it. (the type made out of several pieces snapped together not the newer type made like the bendable part of a straw)
mydlyfkryzis
Years Riding: 42
#6 Unread post by mydlyfkryzis »
Johnj wrote:Get PVC pipe in the proper diameter to fit over your exhaust pipe and run it out the door. Get a couple 45º fittings and a can of PVC glue and custom make them so they drop to the floor and run under the garage door. You could even install dryer vents in the wall and get some flex pipe in the proper diameter.
PVC will melt. I wouldn't recommend it.
Richard - Fully Dressed
Naked 1976 Honda CB360T
#7 Unread post by Johnj »
And stink.
