A concern about Headlight Modulators
jetmech727
#1 Unread post by jetmech727 »
I just had a look at those Headlight Modulators on the Kisan website. While looking at it, a major concern came to mind......what if some crazy donkey takes the flashing highbeam as a signal that your giving up the right of way?...thinking your telling him to make his left turn in front of you? Out here in Toronto I can see that happening. What do you all think?
iwannadie
Re: A concern about Headlight Modulators
#2 Unread post by iwannadie »
ya that or your flashing him cause your mad which will invite retaliation. or people thinking your headlight is broken and will try and warn you about it. or might even confuse their sense of distance, which is bad enough when looking at a bike.
im all for being seen but flashing headlights just inst a good idea i think, the flashing brake lights that only flash for a second then go solid seem ok, but the ones that flash at all times i think people would see and not realize its a Brake light.
jetmech727 wrote:I just had a look at those Headlight Modulators on the Kisan website. While looking at it, a major concern came to mind......what if some crazy donkey takes the flashing highbeam as a signal that your giving up the right of way?...thinking your telling him to make his left turn in front of you? Out here in Toronto I can see that happening. What do you all think?
Abner
#3 Unread post by Abner »
Unless the driver is drunk, I think it's impossible for them to confuse a modulating headlight for any sort of indicator for right of way. With a drunk driver nothing can help, they don't even see cars or trucks.
Here in the US in order for a headlight modulator to be legal it must flash no more that 240 times per minute or about 4 times a second. Flashing at 4 times per second it's hard for anyone to think that you are manually flashing your headlight. You can visit www.kriss.com/modrules.htm and in there they talk about regulations for the USA and Canada. They also have links to the official goverment sites for both countries.
I have one of their headlight modulators and I guarantee you that it works great!! I would not own a bike without one. I have not had any close calls or anyone ever getting confused that I was yielding right of way.
Headlight modulators are a MUST HAVE peice of safety equipment!
Black 2005 Honda Spirit 1100
jetmech727
#4 Unread post by jetmech727 »
Thanks for clearing that up. I did not realize it flashed that quickly. I had the impression that it was sort of an on off slow pulse. I guess if it's almost strob like, that it could make a big difference.
Itzamna
#5 Unread post by Itzamna »
Also read into your local laws. Just because it's legal in a nation or state, does not neccessarily make it legal in your local area. I don't think they're legal around here because I have never seen one here. When I went to Michigan, it seemed 2 out of 3 had a headlight modulator. I just ride with my brights on everywhere. :twisted: They always seem to notice me then, since they're always flashing their lights at me. :laughing:
Brian
'03 Suzuki SV1000
kfranklin
#6 Unread post by kfranklin »
Kriss claims that their headlight modulators are legal in all 50 states.
Ken
Who Loves His Shadow Tourer
Renegade
#7 Unread post by Renegade »
The headlight modulates pretty fast and steady... and you can control it. (It's your HighBeam)
If you have it on constantly like I do I have yet to have someone confuse it with a signal. :banging:
Renegade
Admin @ [url]http://www.twowheeltouring.net[/url]
IBA#21342
Wanna win some tires?
[url=http://www.twowheeltouring.net/raffles/raffle.php]http://www.twowheeltouring.net/raffles/raffle.php[/url]
mydlyfkryzis
Years Riding: 42
#8 Unread post by mydlyfkryzis »
Itzamna wrote:Also read into your local laws. Just because it's legal in a nation or state, does not neccessarily make it legal in your local area. I don't think they're legal around here because I have never seen one here. When I went to Michigan, it seemed 2 out of 3 had a headlight modulator. I just ride with my brights on everywhere. :twisted: They always seem to notice me then, since they're always flashing their lights at me. :laughing:
If your modulator complies with FMVSS 108, then the state has to accept it. This doesn't mean you won't get stopped or get a ticket. Some LEO's are not keen to every nuance of the law. However, you would easily beat the ticket in court. The modu;ators are legal in all 50 states.
Here's some of the law:
This Federal law supersedes all state laws and makes motorcycle headlight modulators
legal in all 50 states. FMVSS 108 (Federal Motor Vehicle Safety Standards) (49 CFR Part
571.108 S7.9.4) allows motorcycle headlight modulation systems all 50 states provided they
comply with the standards set forth in this section. Title 49 USC 30103 (b1) (US Codes)
prohibits any state from forbidding a system that conforms to FMVSS 108. Click here to
see the regulation.
Code of Federal Regulation - Title 49, Volume 5, Parts 400 to 999 - Revised as of October 1, 2000
From the U.S. Government Printing Office via GPO Access [CITE: 49CFR571.108] [Page 236-307]
TITLE 49: TRANSPORTATION - CHAPTER V, NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION,
DEPARTMENT OF TRANSPORTATION PART 571, FEDERAL MOTOR VEHICLE SAFETY STANDARDS -
Subpart B--Federal Motor Vehicle Safety Standards - Sec. 571.108 Standard No. 108;
Lamps, reflective devices, and associated equipment - S7.9.4 Motorcycle headlamp modulation system.
S7.9.4.1 A headlamp on a motorcycle may be wired to modulate either the upper beam or the lower beam from its
maximum intensity to a lesser intensity, provided that:
(a) The rate of modulation shall be 240 <plus-minus> 40 cycles per minute.
(b) The headlamp shall be operated at maximum power for 50 to 70 percent of each cycle.
(c) The lowest intensity at any test point shall be not less than 17 percent of the maximum intensity measured at
the same point.
(d) The modulator switch shall be wired in the power lead of the beam filament being modulated and not in the
ground side of the circuit.
(e) Means shall be provided so that both the lower beam and upper beam remain operable in the event of a
modulator failure.
(f) The system shall include a sensor mounted with the axis of its sensing element perpendicular to a horizontal
plane. Headlamp modulation shall cease whenever the level of light emitted by a tungsten filament light operating
at 3000 deg. Kelvin is either less than 270 lux (25 foot-candles) of direct light for upward pointing sensors or less
than 60 lux (5.6 foot-candles) of reflected light for downward pointing sensors. The light is measured by a silicon
cell type light meter that is located at the sensor and pointing in the same direction as the sensor. A Kodak Gray
Card (Kodak R-27) is placed at ground level to simulate the road surface in testing downward pointing sensors.
(g) When tested in accordance with the test profile shown in Figure 9, the voltage drop across the modulator when
the lamp is on at all test conditions for 12 volt systems and 6 volt systems shall not be greater than .45 volt. The
modulator shall meet all the provisions of the standard after completion of the test profile shown in Figure 9.
(h) Means shall be provided so that both the lower and upper beam function at design voltage when the headlamp
control switch is in either the lower or upper beam position when the modulator is off.
S7.9.4.2(a) Each motorcycle headlamp modulator not intended as original equipment, or its container, shall be
labeled with the maximum wattage, and the minimum wattage appropriate for its use. Additionally, each such
modulator shall comply with S7.9.4.1 (a) through (g) when connected to a headlamp of the maximum rated power
and a headlamp of the minimum rated power, and shall provide means so that the modulated beam functions at
design voltage when the modulator is off.
(b) Instructions, with a diagram, shall be provided for mounting the light sensor including location on the
motorcycle, distance above the road surface, and orientation with respect to the light.
Richard - Fully Dressed
Naked 1976 Honda CB360T
Joe Mc
#9 Unread post by Joe Mc »
I saw a bike with one of these the other day. It was actually very distracting. The guy came around a corner and everyone thought it was an emergency vehicle at first and slowed down. I was a little annoyed and high-beamed the guy. Not a good accessory IMO.
'78 CB400T2 Hawk
Renegade
#10 Unread post by Renegade »
Joe Mc wrote:I saw a bike with one of these the other day. It was actually very distracting. The guy came around a corner and everyone thought it was an emergency vehicle at first and slowed down. I was a little annoyed and high-beamed the guy. Not a good accessory IMO.
But you saw him, and noticed him, so it did it's job which is to make him conspicuous. :righton:
Renegade
IBA#21342
