Computer questions and solutions....thereof...
#511 Unread post by blues2cruise »
I have now uninstalled the AVG free version. It was almost as bad as the trial pay for version.....
I guess it is just incompatible with my system.
I am now trying Trend-Micro. They also have a trial version....
ofblong
Legendary 2500
Legendary 2500
Real Name: Ben
#512 Unread post by ofblong »
the only time avg should give you any problems is when its doing a "scheduled" scan. My guess is you didnt set the scan to run when you were not at the computer but instead had it set to run while on the computer. All anti virus will slow down your computer when scanning your computer.
96' Honda Shadow Deluxe VLX
#513 Unread post by blues2cruise »
ofblong wrote:the only time avg should give you any problems is when its doing a "scheduled" scan. My guess is you didnt set the scan to run when you were not at the computer but instead had it set to run while on the computer. All anti virus will slow down your computer when scanning your computer.
It wasn't when scanning......It was making my computer get hung up and freeze.
Once I uninstalled it it got better.
ofblong
Legendary 2500
Legendary 2500
Real Name: Ben
#514 Unread post by ofblong »
I need to see this computer cause it seems like you have more issues than just anti virus throwing it off. I use avg and it doesnt use a % of my cpu power when idling. I have a feeling you still have some of the norton process's/program still installed and running because that could cause issues with other anti virus programs.
#515 Unread post by blues2cruise »
Thank you. I will do a search and see if there is any more Norton lurking behind the scenes.
ofblong
Legendary 2500
Legendary 2500
Real Name: Ben
#516 Unread post by ofblong »
blues2cruise wrote:Thank you. I will do a search and see if there is any more Norton lurking behind the scenes.
I have been looking but am having a hard time finding the answer I am looking for which involves registry values that need to be removed. Best I have found so far is
http://www.cit.cornell.edu/security/sym ... llnav.html
Question regarding computer networks
#517 Unread post by blues2cruise »
Hello all you network administrators. My inquiring mind has a question.
Why do the computers in an office run so slow, or get the never ending hourglass, or always freezes up and then logging out and logging back in is neccesary?
This is what the system is like where I work. It is so frustrating trying to do a good job and work efficiently when the computer system is so bad.
Is it because the server is too small? We are on a network and the help desk is in the USA.....(Our office is in Canada)
Yesterday the system crashed and we all had to sit and twiddle thumbs while they figured out what to do.
The company sunk a lot of money into creating this new entity but so far they have proved very inept.
JC Viper
Real Name: JC
Re: Question regarding computer networks
#518 Unread post by JC Viper »
blues2cruise wrote:Hello all you network administrators. My inquiring mind has a question.
Possibly too many unnecessary background applications are running taking the system resources and can be a pain with an underpowered system. Are you getting the hour glass when accessing a program or when trying to load a web page or sending files through the network?
#519 Unread post by blues2cruise »
sending files through the network. simple things like editing an entry creates slowdowns.
As you said, it's probably underpowered for how many computers are on the system.
MrShake
#520 Unread post by MrShake »
Its probably more likely a network infrastructure issue than a server size issue.
1976 Golding GL1000 Bagger
