p.s. - at least she runs alot better now. clean carbs.
There's a yellow tube of goop called "Seal-All" that will work. I used it on a gas tank on an old Chevette once and on a few of my older bikes to plug leaks in the fuel system. It will harden even if gas is still dripping/leaking out of the hole, so I think it should work if you just want to smear it around the t-fitting in your carbs. Word of warning - it will be hard to separate them when you do finally get around to doing a proper fix; the stuff acts like a contact cement as well as a sealer.txbadboy wrote:some sort of molding agent to withstand petroleum byproducts
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
