ARE HARLEYS WHAT THEY ARE CRACKED UP TO BE?
koji52
#71 Unread post by koji52 »
it's set at the softest setting but it's an aftermarket shock...i have the box for it (which holds the stock shocks) but that's in another box with the rest of the stock parts. I don't remember the brand. The suspension is fine (major upgrade from the stock shocks of the xl). It's the limited lean clearance that is kind of annoying me. I'll probably get used to it and lean less into turns as time goes on.
The lean clearance was great on the sporty. I have scraped my pipe and pegs before but that's at a much sharper angle than the vrod allows.
2008 HD VRSC-DX Night Rod Special
2008 Buell 1125R
HYPERR
#72 Unread post by HYPERR »
koji52 wrote:it's set at the softest setting but it's an aftermarket shock...i have the box for it (which holds the stock shocks) but that's in another box with the rest of the stock parts. I don't remember the brand. The suspension is fine (major upgrade from the stock shocks of the xl). It's the limited lean clearance that is kind of annoying me. I'll probably get used to it and lean less into turns as time goes on.
That's good as the stock shock is a piece of dodo, and an aftermarket shock would have been an mandatory upgrade so the previous owner saved you some money right there.
Yes agreed on the very limited lean clearance but actually you would be surprised how much less scraping you would do by stiffening the rear shock.
koji52
#73 Unread post by koji52 »
Interesting, thanks for the tip...i'll knock the setting up to the top notch then and let you know how it works. I was out yesterday and was about to tear around a curve like I usually do on the sporty then decided not to. All I heard was a scraping sound and a part of my soul withering away. :crybaby: :frusty:
I got a great great deal on the bike though either way. 12,000 for a vrod with less than 700 miles and a bunch of aftermarket stuff? YOu can beat that right?
2008 Buell 1125R
HYPERR
#74 Unread post by HYPERR »
koji52 wrote:Interesting, thanks for the tip...i'll knock the setting up to the top notch then and let you know how it works. I was out yesterday and was about to tear around a curve like I usually do on the sporty then decided not to. All I heard was a scraping sound and a part of my soul withering away. :crybaby: :frusty:
I just noticed that you said you have it in the softest setting. How much do you weight?
koji52
#75 Unread post by koji52 »
160lbs of steel and thunder.
Or just the 160lbs part.
2008 Buell 1125R
HYPERR
#76 Unread post by HYPERR »
koji52 wrote:160lbs of steel and thunder.
You are no heavyweight but certainly probably waaay too heavy for the softest setting. I don't recall the VRod scraping the pegs that easily..... and especially with aftermarket shocks.
You should see a noticeable difference once you set it stiffer. Just don't expect the cornering clearance of a Racer Replica. :laughing:
Gummiente
Years Riding: 38
My Motorcycle: 03 Super Glide
#77 Unread post by Gummiente »
HYPERR wrote:You gotta admit, some of the model designations are quite long; such as the FLHTCUI designation for the Electra Glide Ultra Classic.
FLHTCU, actually... the "I" was dropped when fuel injection was installed on all FL models and no longer an optional choice.
Pop quiz... what is an IMZ-8.1037?
:canada: Mike :gummiente:
It isn't WHAT you ride,
It's THAT you ride
HYPERR
#78 Unread post by HYPERR »
not a clue...... :wacko:
Gummiente
Years Riding: 38
#79 Unread post by Gummiente »
HYPERR wrote:not a clue...... :wacko:
It's the Ural Sahara...
...speaking of confusing model designations. :wink: :lol:
It's THAT you ride
koji52
#80 Unread post by koji52 »
haha...yea i'll change it tomorrow and see how what happens. Thanks man and thumbs up to ya.
2008 Buell 1125R
