How do you work on your bike?
picma
#1 Unread post by picma »
I have just bought a 1994 Honda Shadow 600. This bike as you know does not have a centerstand. It's been 15 years since I last had a bike and it did have a centerstand. How do you guys change the oil or oil the chain on these bikes without having a centerstand. I have looked on the web and seen several ideas, such as the 6x8 piece of wood you put under the motor. But I don't see a place where I can do that without putting presure on the motor itself or bending something. Please tell me how you do it.
ZooTech
Years Riding: 18
#2 Unread post by ZooTech »
One of THESE.
Wizzard
#3 Unread post by Wizzard »
I have a bro who owns a muffler shop and he makes lifts out of muffler pipe that work on the fulcrum principle . And works rather well I might add . Cost me a whopping $35.00USD. Wrapped an old towel and secured it with masking tape to the bar that holds the scoot to avoid damaging any paint . Ya see , my bike is so low that I can't even get an oil pan underneath it .
As far as oiling the chain , ya can always have someone sit and walk your scoot along while ya do that .
Oh and btw , welcome to the forums picma .
Kind regards, Wizzard
picma
#4 Unread post by picma »
Thanks guys. Some great ideas. I might try to make something.....gives me something to do while it's raining.
#5 Unread post by Sev »
kickstand holds it high enough :D
Aggroton
#6 Unread post by Aggroton »
i use a ramp and cinderblocks....
thats a sweet bike.
ronboskz650sr
#7 Unread post by ronboskz650sr »
For wheel removal, I ratchet strap the opposite end to my workbench leg with two straps at a total angle of 90 degrees to each other attached to the lower shelf in holes I drilled for that purpose. Then I just put a low car jack under my center stand brackets (you can jack on the engine , too.) The unstrapped end comes right up. Secure it with jackstands under the frame, or swingarm or engine guard...whatever you can find, and you can maintain/repair to your heart's content.
I do forks, steering head, chain/sprocket replacement, pretty much anything that needs a wheel up. We had ratchet straps and jacks/stands already, so this was a freebie.
Ride safe...God bless!
-Ron
ultimax
#8 Unread post by ultimax »
Here's how I raise my Virago 125 to lube/tighten the chain. I can drain the bike's engine oil without having to raise it.
1. Block / brick under the sidestand
2. Car jack from a scrap yard (couple of bucks) under the swing arm
3. Raise the bike
The pic's a bit misleading. No part of the bike touches the jack other than at the swingarm.
[/img]
