More likely lower sprocket life. But this is OK, sprockets wear regardless and should be replaced when the chain is replaced. Figure 20K miles as a rough average.RhadamYgg wrote:Then I'll probably ride it and since I doubt we'll get all the chunks and particles I'll probably have some lower chain life this time around.
Depending on what's involved with a BKing, not a bad idea. The front sprocket cover on my Bonneville comes off with a few bolts. Don't be surprised at the mess under there, chain lube and dirt mix to form nasty glop and it accumulates under the sprocket cover.RhadamYgg wrote:I was even thinking of going so far as to expose the front sprocket to see about getting particles off there as well.
Ummm..... can I make a kinda obvious suggestion? (besides spend a few bucks and buy a frikkin rear wheel stand so you can do maintenance right?) Next time, don't worry so much about seeing what has been lubed. It won't hurt to hit the same section of chain twice. It's probably a sealed O ring chain, all you're doing with the lube is keeping the O rings all nice and oily so they don't dry out.RhadamYgg wrote:We are having a really difficult time seeing what has been lubed and what hasn't -
