2006 Harley Davidson Security System - Total Motorcycle Community Forums
Skip to content
Advanced search
  • Quick links
    • Unanswered topics
    • Active topics
    • Search
  • FAQ
  • Login
  • Register
  • Search
  • Unanswered topics
  • Active topics
  • Print view
Advanced search
4 posts • Page 1 of 1
emosness
  • Quote
#1 Post by emosness » Mon Sep 21, 2009 3:40 pm
I recently purchaced a 2006 Dyna Street Bob. It has a secuity FOB with one button in the middle. When I press it twice the lights flash. I have no other information on this. Can someone explain the operation of the secuity system? I know in 2007 they went ot a buttonless. I have the 2006 version. Plus there is a code I believe enter through the turn signal buttons?
Regards,
Moose
Gummiente
Years Riding: 38
My Motorcycle: 03 Super Glide
  • Quote
#2 Post by Gummiente » Mon Sep 21, 2009 4:02 pm
To arm the system, push and hold the button down until the signal lights flash twice to confirm. To disarm, press the button twice within a 1.5 second time frame and the signal lights will flash once to confirm.
You need to know the code that was programmed into the system before you can disarm it using the turn signal switches, and only then when the key is in the ignition and turned over to the "ACC" position. If you know which dealer the bike was originally purchased from you can contact them and ask what their default security code is. They're not likely to give it to you, though, as they normally use the same code on all their bikes and rely on the customer to enter their own unique code after taking delivery.
:canada: Mike :gummiente:
It isn't WHAT you ride,
It's THAT you ride
emosness
Thanks
  • Quote
#3 Post by emosness » Tue Sep 22, 2009 4:52 pm
Thank you , setting the alarm worked.
CentralOzzy
Real Name: AL
Years Riding: 42
  • Quote
#4 Post by CentralOzzy » Wed Nov 18, 2009 11:46 pm
I found this Information useful.
  • Print view
Jump to
  • ↳   Total Motorcycle Talk
  • News, Events and Stories
  • Reviews
  • Rider Cafe'
  • Off Topic!
  • Total Motorcycle General
  • Board index
  • All times are UTC-11:00
  • Delete cookies
  • Contact us
Privacy | Terms
