I need to change the sitting position to a more relaxed,knees not so bent position on my NH 750,has anybody ever done this?
any suggestions would be appreciated
modifying the sitting position on a 93 Nighthawk 750
I Only Kill Deer Because The Live One's Are Hard To Eat.
93 Nighthawk 750
93 Nighthawk 750
- coffee_brake
- Legendary 300
There's not an aftermarket to put forward pegs on a NH. You can, however, install some highway pegs that will let you stretch out. Some folks install the pegs on engine guards (case savers), and some folks put pegs right on the frame, like I did. Mine are old Harley passenger pegs with mounts to fit the Harley crash guards--they're the same size as the Honda frame.
You can also easily change out the handlebars to get a more upright seating position. There are a lot of options here: www.nighthawk-forums.com
Jenn S.
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
- mydlyfkryzis
- Legendary 500
- Years Riding: 42
I have the same Bike (NH750).
I put these on: http://www.zianet.com/genmar/
1 inch back, 1 inch up.
Allows you to sit more upright.
You will need to play around with the brake, clutch and throttle lines, but the stock will work. I later added Galfer SS Braided brake line that a got a little longer, but the stock lines will work.
Richard - Fully Dressed
Naked 1976 Honda CB360T
