Uh oh, just when all seemed well with my new bike it turns out the engine may have been flooded. The petcock was in PRI instead of On or RES and I noticed fuel leaking from carburetor 1 throat leading to the engine.
I tried to turn on the engine and it wouldn't start but it turns. I took out the spark plugs and noticed that plug 1 was smelling of gas and when I turned the engine while the plugs were out piston 1 was a bit wet and would kick up some oil that smelled a bit of gas out of the plug hole.
Before I go installing new plugs how do I resolve the problem of this possible flooding? Also fuel is leaking very slowly through carb 1 throat and I'm not sure if I should drain it.
It shouldn't be a problem I'm hoping as I was able ride it home Tues. and left it sitting on Wed. Not sure if the guy who sold me the bike did it on purpose.
