'81 Honda CM400E Turn signal wiring?
lokitim
#1 Unread post by lokitim »
I am rebuilding a Honda CM400E & having trouble with rear turn signals.
Can anyone let me know what color wires & where they lead to - flasher, etc. ?
I have the wiring diagram, but it is unclear where they connect to.
Thanks,
lokitim
lc-chucky
Re: '81 Honda CM400E Turn signal wiring?
#2 Unread post by lc-chucky »
may be a bit late
Light-blue = Right rear turn signal
Orange = Left rear turn signal
Green/Yellow = Rear stop light
Brown = Tail light
Green = ―
lokitim
#3 Unread post by lokitim »
Thanks.
What wires go into flasher unit?
lc-chucky
#4 Unread post by lc-chucky »
For the flasher-unit you need the black and the grey, unless you have a German model with a 3 wire unit, that also needs a green.
