Ladies - Found Flat Spots on Front Rim
RocketGirl
Real Name: Belynn
My Motorcycle: 2007 Yamaha Virago 250
#1 Unread post by RocketGirl »
Hi All,
While looking for the reason why my front tire went flat, I decided to inspect the rim and found two flats spots almost 1" in length and close to each other, i.e. one on the right side of the rim and the other on the left. So now I'm trying to figure out what needs to be replaced. I know I'll need a new tire and tube. Because of the flat spots, I'm inclined to go ahead and replace that as well. My question is, does this mean that I'm really looking at getting a completely new wheel, hub, spokes, etc? Can I expect the shop to recommend buying a completely new wheel or can they salvage some components from the existing? Any advice or resource you can point me to is appreciated. Thank you! :?
about 7,000 miles
original tire
Cheng Shin 3.00-18
Re: Ladies - Found Flat Spots on Front Rim
#2 Unread post by dr_bar »
If it's a tube and tire, as long as the bead holds I think it should be ok. Just make sure the bead will hold and that it's balanced. The flat spots sounds like someone hit a curb or a deep pothole maybe at some time. It could also explain the flat tire...
#3 Unread post by Johnj »
If it's a spoked wheel than a new hub is in order. New spokes may or may not be needed.The rest of the wheel will be fine
#4 Unread post by Wrider »
Pictures would help for sure in this case. But I'm with Doc in that if they the bead you should be ok. Since it's spoked a lot of times you can bend it back out and re-true the wheel.
coffee_brake
#5 Unread post by coffee_brake »
It's a Virago 250. A used straight wheel from Ebay is going to be your best bet.
That, and no more curb jumping! :?
Jenn S.
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
RocketGirl
Real Name: Belynn
#6 Unread post by RocketGirl »
Hi All,
Finally got the proper sized tire. Wheel and everything are back together. I've been breaking in the new tire. :) The dents in the rim seem to be a non-issue. The tire pressure is holding up consistently. Yes, no more curb jumping for me and I'm avoiding that awful railroad crossing near Lums Pond SP! Thanks again for all your comments and suggestions.
