which to try first?
maximnewb
which to try first?
#1 Unread post by maximnewb »
There's a few things wrong with my bike...and I'd like to tackle the jobs from easiest to hardest (to ease the process of getting my feet wet with bike repair)
Should I rebuild carbs first, or change the fork seals? First time doing both on a motorcycle :o but I've done performace mountain bike forks before.
Thanks.
cb360
#2 Unread post by cb360 »
I've done both - if you are going to do both anyway, I don't see that it matters very much which you do first.
1974 Honda CB360
1985 Honda Magna VF700c
maximnewb
#3 Unread post by maximnewb »
I'd like to try the easier of the two tasks first, and then depending how that one goes try the other.
So any opinions as to which was/is easier for you?
Wizzard
#4 Unread post by Wizzard »
If it were me , I would rebuild the carbs first . Since that seems like the easist to me . Besides which at that point you can at least get it running and see what else you may be needing to do .
Just my 2¢ worth.
Regards , Wizzard
dreambike05
#5 Unread post by dreambike05 »
if you can have it and do it both why the need to choose anyway?!!!! :shock:
[url=http://www.motorcyclepartstrade.com]Motorcycle apparel[/url] gave me GrEaT dRiVinG AdVenTuREs!
