Brand new Bandit 1250S over steering a lot
Re: Brand new Bandit 1250S over steering a lot
I am really glad to see the community helping the fellow rider here out so much.
Well done guys (and gals).
- Real Name: Martin
- Years Riding: 5
- My Motorcycle: 2010/Suzuki/GSF 1250S
Thanks for the tips guys. Its just that i paid over twice the price of the motorcycle to get it here in India (over $ 18,000, 120% import duties :-S) but its been a real disappointment to ride since day 1. i hope im able to sort out this whole issue tomorrow and let you guys know.totalmotorcycle wrote:I am really glad to see the community helping the fellow rider here out so much.
1997 Royal Enfield Standard 500
2004 Royal Enfield Thunderbird 350
2005 Royal Enfield Machismo 350
2008 Royal Enfield Machismo 500
2010 Suzuki Bandit 1250S
- HYPERR
For your bike to dive AND oversteer, the suspension setting is seriously screwed up. Once you get it dialed in right, it will feel like night and day. First you need to set the rear sag then the front sag. Does your bike have a centerstand by the way?deadman23 wrote:Thanks for the tips guys. Its just that i paid over twice the price of the motorcycle to get it here in India (over $ 18,000, 120% import duties :-S) but its been a real disappointment to ride since day 1. i hope im able to sort out this whole issue tomorrow and let you guys know.totalmotorcycle wrote:I am really glad to see the community helping the fellow rider here out so much.
- Real Name: Martin
- Years Riding: 5
yea, it has a centre stand.
- Real Name: Ryan
Check my post above. Has everything you'll need in it.
- HYPERR
That makes it very easy then. You will ideally need 2 friends in which one must be semi coordinated and have reasonable strength, the other must know how to use a tape measure.deadman23 wrote:yea, it has a centre stand.
Rear Rider Sag
1. Put the bike on the centerstand amd with the rear wheel off the ground measure the distance from the center of the rear wheel axle to a pre-selected position. Record this distance.
2. The full rear suspension travel of your bike is 5.35in. You want to compress that about 30% so that would be about 1.6in (40mm). This is how much rider sag you want in the rear.
3. Take the bike off the centerstand, sit on the bike and put your feet on the pegs and resume your normal riding position with whatever gear you usually wear. One of your friends must balance the bike from the rear and hold it upright. The other friend now measures the distance between the two points used previously. Adjust the rear shock pre-load until that distance is decreased by 40mm.
Front Sag
1. Put the bike on the centerstand and push down on the rear so the front tire comes off the ground. Measure the distance between the top and bottom of the fork sliders. It should be 5.12inches according to the manufacturer's spec.
2. Find 30% of that distance. If it is indeed 5.12in, then it would be 1.536in (39mm).
3. Take the bike off the centerstand, sit on the bike as before and have a friend steady the bike while the other friend measures the distance of the sliders. Adjust the front pre-load until the distance decreased by 39mm.
- Real Name: Martin
- Years Riding: 5
Thank you Wrider.Wrider wrote:Check my post above. Has everything you'll need in it.
- Real Name: Martin
- Years Riding: 5
Thanks for doing all the math for me.HYPERR wrote:That makes it very easy then. You will ideally need 2 friends in which one must be semi coordinated and have reasonable strength, the other must know how to use a tape measure.deadman23 wrote:yea, it has a centre stand.
Rear Rider Sag
Front Sag
Wow, 120% import duties? Luckily the Bandit 1250S is one of the BEST deals on the market for a bike bike.
I'm sure you will like it once you get it sorted.
- Real Name: Martin
- Years Riding: 5
124% import duties to be precise. You should check the prices of all imported motorcycles in India, you will be baffled.totalmotorcycle wrote:Wow, 120% import duties? Luckily the Bandit 1250S is one of the BEST deals on the market for a bike bike.I'm sure you will like it once you get it sorted.
let me give you an idea of how much some popular motorcycles cost in India.
hayabusa - $30,103
GSXR1000 - $28,465
R1 - $28,670
:-S
