Are there scooter that can also cruise at 65 mph ?
Re: Are there scooter that can also cruise at 65 mph ?
#11 Unread post by Wrider »
Oh we're going for a comprehensive list?
Add the Burgman 650 to that.
Add the Yamaha Majesty
Add the Honda Silverwing
And if you're willing to do a bit of modifying, the Honda Ruckus can do it as well.
sapaul
#12 Unread post by sapaul »
Add the Kymco 500 Exciting to the list and then compare prices against the others.
Marvin
Real Name: Bart
My Motorcycle: 2009 Yamaha TMAX, 2005 Yamaha FZ6
#13 Unread post by Marvin »
Dirt Dobber is correct , the larger diamater tires on the Tmax makes it the best handling super scooter out there, the Honda Silver Wing and the Suzuki 650 Burgman are faster than the Tmax but the Tmax is much better in ride quality and handling, the Tmax is better balanced where you can hold it up while stopped at a red light without your feet on the ground.
The Tmax is a much better engineered design while the Burgman and Silver Wing is an older, or old school scooter design, the Tmax centers all its weight at the bottom center of gravity and the Tmax uses the same front brake system as the R6, think of the Tmax as the sport bike, or crotch rocket of the scooter family.
I have experience riding the Burgman and it was my first choice before buying the Tmax but I only bought the Tmax because the Suzuki Dealers were a**holes and they made it impossible for me to buy one, so I was stuck buying the Tmax and I am very happy with it
2009 Yamaha TMAX
2008 Suzuki King Quad 750AXI
#14 Unread post by Wrider »
Yet again incorrect...
It uses an "R6 inspired front brake". IOW it's got a disc brake with multiple pots (too lazy to look up exact specs at the moment.)
If it had the same front brake it'd require a 17 inch front wheel like the R6 has just to clear the rotor and caliper.
Oh, and all of them can be held up at a traffic light with your feet on the ground. Not sure where you were going with that.
dirt dobber
Real Name: james
#15 Unread post by dirt dobber »
Wrider,,marvin was talking about balanceing it stopped at a light with no feet on ground at all, i couldn't do it myself but, i heard about some one doing it for 15 seconds. i only rode mine 8300 miles. if you want to know about tmax & have a Yahoo account go to tmaxusa: Tmax USA.
#16 Unread post by Wrider »
Oh then I apologize, I misread that. But in fairness, most can do it if they have good balance even on sportbikes with super high COGs.
Marvin
Real Name: Bart
#17 Unread post by Marvin »
Wrider? ohhh wow you're sooo cool! you are such a professional motorcycle rider, I I I wish I was as good as a rider as you, ohhh wow!
2009 Yamaha TMAX
#18 Unread post by Wrider »
Marvin wrote:Wrider? ohhh wow you're sooo cool! you are such a professional motorcycle rider, I I I wish I was as good as a rider as you, ohhh wow!
Don't worry, eventually you'll get there! Oh and low COG is harder to balance at a light. As a point to prove it, take a mop or broom or something like that, balance it upright on the handle end, then balance it on the mop/broom head end. You'll find it's not hard to balance on the handle end but a lot harder on the head end.
