Even if they did make it up there (would never happen), nothing would come of it. The temps in the exhaust manifold are just as hot, so whatever the flames would ignite would already be burning. My bike is designed to burn unspent air/fuel mixture in the exhaust for emmisions, that's why I will have to put coasters (block off plates) over the emmisions system if I ever change out the pipes (the catalytic converter muffles the backfiring in stock form).iwannadie wrote: i was just worried bout the flames leaking back up the exhaust to the motor but i guess thats not likely with the preasure the exhaust comes out with.
ya i read id deffinetly need to pull my cat out of there. wanted to do that anyways. its stock from 87 im sure its not actually helping emission by this point anyways. be easy to throw a test pipe in its place.ZooTech wrote:Even if they did make it up there (would never happen), nothing would come of it. The temps in the exhaust manifold are just as hot, so whatever the flames would ignite would already be burning. My bike is designed to burn unspent air/fuel mixture in the exhaust for emmisions, that's why I will have to put coasters (block off plates) over the emmisions system if I ever change out the pipes (the catalytic converter muffles the backfiring in stock form).iwannadie wrote: i was just worried bout the flames leaking back up the exhaust to the motor but i guess thats not likely with the preasure the exhaust comes out with.
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
