removing gas tank warning labels
rubthebuddha
#1 Unread post by rubthebuddha »
What's the best way to remove those warning labels on your gas tank w/o fing up your paint?
THX
9000white
#2 Unread post by 9000white »
heat them up with a hair dryer and pull them off.
dr bob
#3 Unread post by Sev »
then a little palmolive+water and some rubbing with a soft cloth will take off any left over glue.
rubthebuddha
#4 Unread post by rubthebuddha »
Cool
Thanks for the tip. :righton:
Craig7220
#5 Unread post by Craig7220 »
I used soap and warm water. It takes awhile to get it off. The left over glue is tough but with alittle rubbing with a soft cloth it will come off.
Craig
2005 Suzuki C-50 Limited
Loonette
Real Name: Kristin
Years Riding: 13
#6 Unread post by Loonette »
Goo Gone works pretty well (if you use it though, don't combine it with heat - it is an oil, thus combustable).
Cheers,
Loonette
2006 Mean Streak 1600
