Idle Problem: V-Star 650
1. This is a 2008 Yamaha V-Star 650, with carburetors (not injected) with 5,600 miles on it. I checked all the mechanical parts and lubricated the cables. Mechanically everything returns to the idle stop screw when the throttle is released.
2. When the engine gets hot it begins to idle very fast and won’t return to normal idle speed when throttle is returned to fully released position.
3. The problem occurs only after riding for a while and mostly but not always at high speed.
4. This happens regardless whether the motorcycle is on the road or stopped; clutch engaged or not engaged.
5. When the motorcycle slows to a stop the engine light sometimes comes on.
6. The problem resolves when the motorcycle is shifted into neutral.
7. Since the engine returns to normal idle when the transmission is shifted into neutral this appears to be an electrical, rev limiter, or sensor problem.
Can anyone help point me in the right direction to correct this problem?
Earl
Yamaha V Star 650 won't drop down to idle when hot
- Site Supporter - Silver
- Real Name: Pete
- Years Riding: 10
Re: Yamaha V Star 650 won't drop down to idle when hot
Air leaks by carb?
- Tricycle Squid
- Real Name: jerry
- Years Riding: 20
- My Motorcycle: yamaha 2007 vstar 1100 classic
I Have 2007 vstar 1100 classic doing the same thing driving me crazy, changed fuel pump & fuel filter ,cleaned air filter , same
- Johnj
- Real Name: Johnny Strabler
Sounds like an air leak. Try replacing all vacuum hoses.
- Real Name: Ryan
Agreed with Johnj. Check for air leaks by spraying carb cleaner around any and all vacuum hoses and the carb boots.
