Please help. 250 bandit won't start
tonyhill
Real Name: tony hill
My Motorcycle: 1992 Suzuki gsf250
#1 Unread post by tonyhill »
I rode this bike around for 2 weeks before i bought it and didn't have a problem. About a month after i paid for it I started having trouble starting it. About a week after that it wouldn't start at all.
I just got it back from the shop where they fixed a broken carburetor spring, replaced a kinked fuel line and did a full service. But the bike still won't start. The mechanic doesn't know what else to try. The bike is getting fuel and spark and the compression is fine.
When I try to start it, it doesn't even get that "cough" sound, just the wind.
Any ideas before I give up on it?
GS_in_CO
Real Name: Ron
Re: Please help. 250 bandit won't start
#2 Unread post by GS_in_CO »
tonyhill wrote:I rode this bike around for 2 weeks before i bought it and didn't have a problem. About a month after i paid for it I started having trouble starting it. About a week after that it wouldn't start at all.
Broken carburetor spring????? What function did the spring serve?
How do you know it's getting fuel?(what test are you using for this)
Are you using the choke? Is the choke working? (linkage, extra fuel to spark plug.....)
What kind of gunk comes out of the carburetor bowl when drained? What's the history of the gasoline in the tank both before you bought it and after?
Combustion is simple- air, fuel, compression, spark. At the right times and right combinations.
If the bike was running before - there's no good reason to give up yet. (This "mechanic" might be deficient in knowlege of the fundamentals or in persistance. Or doesn't have a service manual to help with how to check spark timing....)
Ron
Past: 1987 Yamaha XT350
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
BRUMBEAR
Real Name: Dave
Years Riding: 40
#3 Unread post by BRUMBEAR »
Yeah I got the same questions and more is the plug wet or dry?
Kickstand switch?
Kill switch?
cdi grounding?
there aint nothin like it
WrenchLife
Real Name: Phil
Years Riding: 2
My Motorcycle: 1994 Honda Shadow vlx 600
#4 Unread post by WrenchLife »
I feel like this sounds like a fire issue more than fuel. I would but a inline spark tester on the spark plug wire and not rule it out till I saw the blue spark
