carbs
- Hanson
- Legendary 300
- Real Name: Richard Hanson
- Years Riding: 3
Re: carbs
I don't have an answer to your question, but I would like to welcome you to Total Motorcycle. Check back in a day or two and someone will likely have some good tips to help you.
- Johnj
- Real Name: Johnny Strabler
Re: carbs
Hello Willie and welcome to the forum. You most likely need to clean your carbs. Instructions are in your service manual.
- Johnj
Re: carbs
May I ask what makes you think that the front cylinder is running lean.
Does your bike have one carb or two?
Have you modified your exhaust?
- BRUMBEAR
- Legendary 1000
- Real Name: Dave
- Years Riding: 40
Re: carbs
+1 to John also if its a plug issue that makes you think your running lean on 1 cyl like its whiter and caked before you go crazy, check for air leaks as they are the main culprit for running extremely lean.
if you have a cv check your diaphram but a single carb v twin it's usually an air leak or valve adjustment issue or both
Hope this helps
Hope this helps
there aint nothin like it
- Real Name: willie w
- Years Riding: 1
- My Motorcycle: kawasaki vulcan 900
Re: carbs
Thanks for your input, I'm not that handy with motors. But thisJohnj wrote:May I ask what makes you think that the front cylinder is running lean.
Is what makes me think it is runing lean. I front cylinder won't
Run until I pull the back spark plug open the choke and turn
The throttle about a 1/4 turn. And then it spuders a lot
- Years Riding: 1
Re: carbs
Thanks for the vido, how's the best way to check for air leaksBRUMBEAR wrote:+1 to John also if its a plug issue that makes you think your running lean on 1 cyl like its whiter and caked before you go crazy, check for air leaks as they are the main culprit for running extremely lean.
Hope this helps
