1987 Yamaha radian yx600 clutch problem
- Tricycle Squid
- Real Name: Rob papa
- Years Riding: 10
- My Motorcycle: 1987 Yamaha radian yx600 bobber
I have a 1987 radian. It's stars fine in neutral, but when I pull the clutch and put it in gear it jumps and dies. I've adjusted the cable at the top and bottom, but it won't disengage.
- Johnj
- Real Name: Johnny Strabler
Re: 1987 Yamaha radian yx600 clutch problem
Either your clutch plates are all stuck together or your clutch basket has problems. It might be the push rod or the clutch basket (the inner or the outer or both). Good luck.
- Real Name: fagiki
- Years Riding: 3
- My Motorcycle: 1992 yamaha rs
My bicycle begins fine in impartial yet when I pull grip switch and put into first it hops and passes on. Any thoughts why the grasp isn't withdrawing. I have balanced it looser and more tight with no karma. Thank ahead of time.
- Tricycle Squid
- My Motorcycle: moto
Everything will get better if you really focus on it. Your information too, I'm sure you focused a lot on getting a full article.
