Battery Tender System.
ceemes
Real Name: a big secret
#1 Unread post by ceemes »
Hooked up a Battery Tender system to my bike and I was wondering if it is possible or advisable to use the connection from the battery as a power source for other things, such as aux. power for a cam or gps system while riding?
Re: Battery Tender System.
#2 Unread post by Johnj »
It is possible. but you have to hook it up correctly or you let the smoke out.
GS_in_CO
Real Name: Ron
#3 Unread post by GS_in_CO »
Put a fuse in the line. That's how you let the smoke out in a less damaging way if the smoke needs to get out.
Ron
Past: 1987 Yamaha XT350
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
ceemes
#4 Unread post by ceemes »
GS_in_CO wrote:Put a fuse in the line. That's how you let the smoke out in a less damaging way if the smoke needs to get out.
There is a 25 Amp fuse from the positive terminal connector line. Fairly simple set-up. Unscrew the battery lead and rescrew them back on with the tender lead on top....the connector pokes up between the gas tank and the front of the saddle.....will take some pics later.
slimcolo
#5 Unread post by slimcolo »
You need a smaller fuse, more appropriate to your GPS. I would leave the 25 amp in place but add another fuse that will work for GPS but unplug for battery tender use. I plan to do this on my bike but believe my battery tender hook up doesn't have a fuse.
SEE NO EVO
HEAR NO EVO
SPEAK NO EVO
and above all
RIDE NO EVO
Read my blog
