Turn Signal not blinking...
Aggroton
#1 Unread post by Aggroton »
it did this while i was tryin to figure how to wire the signals on. the back will go on but not blink. it does not blink on the controls either. i checked the connections and they are solid. could the bulb just be dead?
thats a sweet bike.
niterider
lites not blinking
#2 Unread post by niterider »
Make sure that both the front and the rear lites are burning on the brightest filament. And that you have a good ground. The rear lite only works for a signal, in most cases the front has two filaments one for running lite the other for turn signal. The brightest are for turning signals. Good luck.
#3 Unread post by BuzZz »
Sounds like your flasher rely has packed it in. It allows power through, but doesn't cut it out to create the flashing.
Aggroton
#4 Unread post by Aggroton »
yeah i forgot to say the front blinker will not blink at all...so the back signal and the instrument signal will stay solid and the front i have nothing.
thats a sweet bike.
Mintbread
#5 Unread post by Mintbread »
Sounds like a simple bulb replacement.
