hello,
I have a 1980 Suzuki gs1000L and on the underside the gas tank on the side is a vent I believe and it's leaking gas when the bike is just sitting there! The bike runs fine and this just started leaking and I don't have any idea why. please help,, thanks
Dave
1980 suzuki gs1000L gas tank vent tube leaking gas
- JackoftheGreen
- Legendary 1000
- Real Name: Eric
- Years Riding: 12
- Contact:
Re: 1980 suzuki gs1000L gas tank vent tube leaking gas
Dave,
Welcome to TMW! Thanks for giving our community the opportunity to help out. This isn't my area, but someone will be along shortly with exactly the answer you're looking for. In the meantime, post some pics of your bike! (-:
- Jack of the Green
Some Awesome Threads:
What Did You Do Today?
Social Media:
TMW on DailyMotion!
The TMW YouTube Channel!
TMW on Facebook!
Patreon
Social Media:
TMW on DailyMotion!
TMW on Facebook!
Patreon
- Site Supporter - Silver
- Real Name: Pete
- Years Riding: 10
I think you may mean the drain from the fuel float cover.
My Bike had a bad gasket. That stopped the drip..
- Legendary 300
- Real Name: Ron
Tanks typically have a valve attached to the bottom - which is where the ON/OFF/Reserve lever usually lives.
If the leak is from a rubber hose attached to the valve it's not a vent.
If the rubber hose is attached directly to the tank and not the valve then it probably IS a vent.
If the tank was really, really full and is warmed up from when it was filled the gas expands and will go out the vent.
Chances are that the rubber hose hasn't been replaced since the bike was new so it is cracked and will leak instead of dribbling fuel out below the bike's frame.
Ron
Past: 1987 Yamaha XT350
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
- Real Name: david kuhar
- Years Riding: 30
- My Motorcycle: 1980 suzuki gs1000L
hello, and thanks for the reply's.
I replaced all the hoses awhile back so no hoses are leaking and it's not where the ON/OFF/Reserve lever usually lives.
the tank is not full and it's dribbling fuel out below the bike's frame. It leaks quite a bit. I mean like 1/4 cup a day.
I believe it's the gasket from the fuel float cover. I ordered one and I'll post my answer when it comes in. thanks again,
Dave
Dave
- Legendary 300
- Real Name: Ron
"Fuel float cover" is part of the carburetor. So it's not a leaking fuel tank hose.daveku wrote:hello, and thanks for the reply's.
Dave
Problem could be a buggered needle valve and seat for the float as well as possible gasket leak.
You could turn the gas off at the tank when it's parked to stop losing gas for no reason.
EDIT- My 2016 New Year's resolution is to stop answering questions here in Troubleshooting. Posters almost never give the other 80% of the information they have about the problem.
Ron
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
