Bike only getting power on high rpm
- Real Name: Svajūnas
- Years Riding: 0
- My Motorcycle: 2005 Derbi Senda
I ride a 2005 derbi senda, it has a 70cc airsal engine and a 12,5 mm carb and it only gets normal power at higher rpm. I can go about 60km/h and it sudently starts to scream and gets up to 80-90km/h ir a few seconds, I know that changing a carburator would fix it but is there anything else I can do?
- Veteran
- Real Name: Miles Hall
- Years Riding: 3
- My Motorcycle: 2016 Ducati Supersport
Re: Bike only getting power on high rpm
Try to check your fuel filter this is one of the common reasons why you are experiencing this problem.
- KayBur
- Real Name: Kay Burton
- Years Riding: 2
- My Motorcycle: JAWA 350 OHC Prima
I recommend cleaning the fuel filter and changing the fuel used. If it contaminates motorcycle parts, then it is clearly not suitable for use.
- Years Riding: 0
The fuel is good, i mix it up myself, but what does fuel have to do with a bike getting a lot of power at mid rpm?KayBur wrote: Thu Apr 08, 2021 4:24 am I recommend cleaning the fuel filter and changing the fuel used. If it contaminates motorcycle parts, then it is clearly not suitable for use.
