1986 Suzuki Intruder VS700 Knock?
Six
My Motorcycle: 86 Suzuki Intruder VS700
#1 Unread post by Six »
Just bought this bike for 500 bucks. Curious if any of you may know what this knock might be?
It does not really change with temperature. Seems consistant. Just changed the oil, and still nothing new.
Thanks for the help. Wondering if I got a good deal, or a bad engine about to blow. :crybaby:
Six
Re: 1986 Suzuki Intruder VS700 Knock?
#2 Unread post by Six »
Any help?
Six
#3 Unread post by Six »
Bump
neelYang
Real Name: Neel Yang
Years Riding: 5
My Motorcycle: KTM 890 DUKE R 2020
#4 Unread post by neelYang »
Sounds like a rode knock. Yes that would most likely be the easiest way to fix this, is to remove the motor. Be sure that there is no damage done to the cylinder walls and etc.
Hi!
Six
#5 Unread post by Six »
neelYang wrote: Wed Nov 03, 2021 1:00 am Sounds like a rode knock. Yes that would most likely be the easiest way to fix this, is to remove the motor. Be sure that there is no damage done to the cylinder walls and etc.
I disconnected the sparks left then right. Still knocks.
NorthernPete
Years Riding: 11
#6 Unread post by NorthernPete »
Bring it to a shop and get a good tune up done. For 500 bucks, you can spend an hour or two shop rate and still come out ahead.
2009 GS500F
bupole
My Motorcycle: po
#7 Unread post by bupole »
THAT was the price two years ago, it should be around 700 dollars now
hudsonchris
Real Name: Hudson Chris
Years Riding: 5
My Motorcycle: Honda
#8 Unread post by hudsonchris »
That was an old price
