New biker question
anaaustin
Real Name: Ana Austin
My Motorcycle: BMW R 1250 GS
New biker question
#1 Unread post by anaaustin »
Hello,
I just got a brand new Husqvarna Vitpilen 401. After the bike was delivered I started it up and immediately noticed what looks to be water leaking out of the bottom? It seems to be coming from a hole in what looks to be either the catalytic converter or residence chamber? I am wondering if this is normal or a problem?
I am new to motorcycles and I’d appreciate any insight. Thanks.
pharmacyfriend
Real Name: Parker James
Years Riding: 15
My Motorcycle: honda
Re: New biker question
#2 Unread post by pharmacyfriend »
The water leaking from the bottom of your Husqvarna Vitpilen 401 is likely just condensation from the exhaust, which is normal when the engine starts up. It usually happens when the engine is cold. If the water continues after the bike warms up or there's too much, it might be worth checking for a coolant leak. Otherwise, it's typically not a problem.
sadiesink951
Real Name: Brandon
Years Riding: 3
My Motorcycle: 2022/honda/ware
#3 Unread post by sadiesink951 »
anaaustin wrote: Sun Nov 10, 2024 5:04 pm Hello,
It’s likely condensation from the exhaust system, which is normal, especially when the engine is cold.
sabrina
Real Name: Sabrina Carpenter
Years Riding: 2
#4 Unread post by sabrina »
Congratulations on your new Husqvarna Vitpilen 401! What you're seeing is most likely normal condensation from the exhaust system. However,Geometry Dash if you're unsure or see signs of a problem, it's always a good idea to consult the dealer or a certified mechanic to ensure everything is in good working order. Happy riding! 🏍️
tereit
Real Name: Thomas Row
Years Riding: 3
My Motorcycle: Ducati
#5 Unread post by tereit »
Congrats on the new Vitpilen 401! That’s a sweet ride. What you're describing sounds pretty normal. It’s likely just condensation from the exhaust system. When the engine heats up, water vapor forms as a byproduct of combustion, and some of it can condense inside the exhaust, especially when the bike is cold. The small hole in the catalytic converter or resonance chamber is a drain to let the water out, so it doesn’t collect and cause corrosion.
You’ll notice it more when starting a cold bike, especially in cooler or humid weather. If it’s clear liquid and stops after the bike warms up, there’s nothing to worry about. If it’s something else (like coolant or oil), that’d be a different story. But from what you’re describing, it sounds totally normal for a new bike
thatsnot
Real Name: thatsnot
Years Riding: 18
My Motorcycle: model 2
#6 Unread post by thatsnot »
Congratulations on your new Vitpilen 401!
